About Bio-Ethanol 114 octane.
Results 1 to 10 of 33
  • Short URL:  http://modifika.si/10068
    1 Day 4 Hrs 24 Mins 36 Secs
    bro, ada maenan baru nih... namnaya bio-ethanol... dulu sempet dipake Ford Focus bioethanol... sekarang aye lg test buat Drag dari campuran 20% ~100%... hasilnya nanti gw rport..
    sementara yg 10% mix dgn Premium hasilnya lumayan, td br dapet kabar klo mix 10% bikin irit dari 1:8km jd 1:9km.
    Note: bio-ethanol merontokan Endapan kerak di Tangki bensin.. penggunaan pertama bila mesin agak telat responnya, Fiter bensin WAJIB dibersihkan....
    Coen
    http://www.drivingethanol.org/motorsports/racing_fuel_characteristics.aspx
    HORSEPOWER: Because Ethanol contains oxygen, it has a very low power stoichiometric when compared to gasoline fuels (6.5 compared to 12.5). Ethanol must be run at much richer mixtures than gasoline, more than offsetting the lower energy per unit volume. The net energy released per cycle is higher and this results in more horsepower.
    For example, if gasoline is run at its preferred max power air fuel mixture of 12.5/1, it will release approximately 19,000 BTU's of energy, where ethanol run at its preferred power stoichiometric of 6.5/1 will release approximately 24,400 BTU's. By comparison, methanol releases slightly more, about 27,650 BTU's. The more ethanol there is in gasoline, the more powerful it is as a motor fuel. Typically, you can expect at least 5% more horsepower at the rear wheels of a vehicle running on E-85 than one burning gasoline only.
    INCREASED ENGINE LIFE: Ethanol has a very high MON octane rating, allowing engine builders to run higher compression ratios without fears of destructive detonation. It also has a very high Latent Heat of Vaporization, so the engine is cooled far better than one running on gasoline. This lowers bottom end and oiling system temperatures substantially.
    REDUCED EMISSIONS: Although reducing emissions usually will not directly affect the on-track performance of a race car, engine parts like pistons and valves tend to stay cleaner. More importantly, there are serious health concerns with many of the octane boosting additives that must be added to racing gasolines in order for them to be compatible with higher compression racing engines. Ethanol fumes are also non-toxic.
    0812-182-862-05
    Banten
    Re: About Bio-Ethanol 114 octane.
    Quote Originally Posted by s515i
    Coen
    ehmmmmmm
    Bos Coen mo tanya neh.....
    pabila filter bensin tidak di bersihkan/diganti resikonya apa???
    kayak filter bensinmu telat ganti aja....
    tarikan rada lemot.... stlh di bersihin, pasti enak lagi eh...
    0812-182-862-05
    klo mobil baru (1~20rb KM) nggak perlu dibersiihin deh.. soalnya tangki bensin masih bebaas karat & endapat bensin....
    0812-182-862-05
    BANDUNG
    3 Hrs 59 Mins 35 Secs
    di mana bisa belinya om?
    berapa?
    "Goldfish Lover" ^_^
    http://www.modupload.com/images/yvzp6mci4zolj11ta4sw_thumb.jpg
    "MOVE TO ANOTHER FORUM........................"
    nanti dulu ya,.. setelah di test,...
    12rb per botol ukuran 1,5liter...
    bisa beli 20,50,100liter dengan wadah khusus...
    Coen
    bisa pesen ke sy
    0812-182-862-05
    Belakang Dunkin Donuts
    3 Days 11 Hrs 38 Mins 40 Secs
    Harusnya kalo bisa merontokkan endapan bukannya justru bisa skalian bersihkan filter bensin?
    Banten
    Hehehehehehehehe......
    bos coen tahu aja deh.....
    iya neh pengen ganti filter bensin.....
    lumayan mahal seh filter bensin....
    BANDUNG
    Coen
    bisa pesen ke sy
    sip dehhh, ntar hasil test nya kasih tau om....
    3 Hrs 50 Mins 16 Secs
    Coen
    kalau mobil gw gimana bro. Terakhir bersihin filter bensin sih 3 bulan yang lalu. Kemarin abis make bio-ethanol, apa perlu filter nya di bersihin lagi?
    Rifki Wiener- B 8610 KA
    Avanza G 1.3 - 2004 - Sparkling Blue
    Juara Umum 3 Kelas 18 dtk Sentul Drag Race 2007
    Contact No: 923 71 560 (24 hours)
Venom 300x250
  1. tanya BIO-ETHANOL
    By daxandree in forum Diskusi Mesin
    Last Post: 19th October 2012, 12:53
  2. [JUAL] BIO ETHANOL POWERMAX 115
    By zonexxx in forum Diskusi Otomotif Lain-Lainnya
    Last Post: 27th August 2008, 23:47
  3. Bio Ethanol & reboisasi daerah pantai
    By Gajah_terbang in forum Diskusi Otomotif Lain-Lainnya
    Last Post: 9th January 2007, 00:52
  4. Conclusion, high octane low octane.
    By phimotorsports in forum Diskusi Otomotif Lain-Lainnya
    Last Post: 25th August 2006, 15:09
