HONDA CIVIC ESTILO D16 SOHC VTEC
SPESIFIKASI
Tipe Mobil:
Honda Civic Estilo tahun 1993
Modifikasi Mesin & Drive Train :
JE PISTON 75,50mm Flat Top with Comp. Ratio 10,5:1
SCAT Connecting Rods
ACL Race Series Bearings
Cylinder Head P08 VTEC Conversion + Ported & Polished head
ARP Head Stud Kit
SUPERTECH Valve Spring
BULLFROG Street Camshaft 261 degree
AEM Cam Gear
MSD Cap Delco
MSD Spark Plug Wire
JACOB Ultra Coil
NGK Iriway 8 Spark Plug
HD Fuel Pump 220 L/H
WORKS ENGINEERING Fuel Pressure Regulator Stage 1
WORKS ENGINEERING Fuel Rail
HKS SPF Filter 200/80mm with CUSTOM Intake Pipe
JR PROJECT Alumunium Race Radiator - 3 Row
BUDDYCLUB Low Temp Fan Switch
SKUNK2 Pro-Series Intake Manifold
CUSTOM Header 4-1
ACT Xtreme with 4-Puck Solid Disc
DASTEK Unichip Type Q
Modifikasi Lain:
KONIi Adjustable Schock Depan & Belakang + Intrax Spring
ULTRA RACING Front Strutbar 3 Points
ULTRA RACING Rear Lower Bar 2 Points
BLOX RACING Rear Lower Control Arm
Sunroof OEM Honda Civic EG
Carbon Hood OEM Style
LED Stop Lamp
PIVOT Stepping Gauge Tachometer with Shiftlight
Indikator Water Temperature & Oil Pressure
Jok Semi Bucket
MOMO Race 2 Steering
SPARCO Pedal M/T
SPOON Duracon Shift Knob
RUNSTOP Front Disc Rotor OEM Size with N-Brake NBP High Performance Brake Pad
RUNSTOP Rear Disc Rotor Drilled OEM Size
POWER 186HP @8500RPM
Dyno Test @RS Tuning/Lestari
UPGRADE PROJECT :
WISECO Custom Piston Kit Bore 76mm with CR 12,5:1
BISIMOTO Camshaft Level X (268deg@0.40)
BISIMOTO Valve Springs
BISIMOTO Cam Gear
GATES RACING Kevlar Timing Belt
SUPERTECH Valves Oversize 0,50mm
OBX Individual Throttle Body 48mm
RC ENGINEERING Injector 310cc
ULTRA RACING Room Bar 2 Point Adjustable
ACT Streetlite Flywheel
ACT Xtreme with 6-Puck Sprung Disc
POWER 216,2HP @9000 RPM
TORQUE 205Nm @7000 RPM
BBM : Bensol
Dyno @RS Tuning/Lestari
SENTUL SERI 1 JUNE 2012 - First Trial
14,4 Sec ~ Better Luck Next Event, Bro..!
GO SOHC POWER...!
