SOLOBARIC L7 15" with RF FosGate 1800Watt Class D
Results 1 to 10 of 23
  • Short URL:  http://modifika.si/10045
    2 Days 8 Hrs 5 Mins 3 Secs
    Kicker solobaric L7 15inch
    spec sub:
    Kicker Solo-Baric L7 Series
    15" subwoofer with dual 2-ohm voice coils
    Power range: 50-1000 RMS watts
    Peak power: 2000 watts
    Frequency range: 18-100 Hz
    Sensitivity: 88.5 dB
    SoloKon aluminum-treated composite cone with Santoprene surround
    Cast-aluminum basket
    Mounting depth: 8-3/16"
    Sealed box volume: 1.5-6.00 cubic feet
    Ported box volume: 3.0-6.0 cu. ft.
    RockFord FosGate 1800watt Class D monoblock
    spec power:
    1800 WATTS
    2-ohm stable
    CEA compliant
    requires a 4-gauge wiring kit ? wiring and hardware not included with amplifier
    MOSFET power supplies and outputs
    MEHSA transfers heat efficiently from the MOSFET devices to the heat sink for high performance
    TOPAZ eliminates ground loop noise
    trans-ANA circuitry keeps preamp signal clean
    NOMAD "intelligent" protection circuitry
    variable low-pass crossover (35-250 Hz, 12 dB/octave)
    variable Punch Bass boost with remote (0-18 dB at 45 Hz)
    11-1/8"W x 2-1/2"H x 13-11/16"D
    klo di kawinin(drive) cocok gak ?? :smt001
    3 Mths 11 Hrs 11 Mins 41 Secs
    Re: SOLOBARIC L7 15" with RF FosGate 1800Watt Class D
    Quote Originally Posted by [ Magic^X
    ]Kicker solobaric L7 15inch
    spec sub:
    spec power:
    1800 WATTS
    2-ohm stable
    CEA compliant
    itu monoblok kuat main 1 ohm kaga...speknya cm 2 ohm stable.....
    kalo kuat hajar boss tinggal bikin box yang mantappp
    kaca depan jaminan geter tuh kalo boxnya bner.....
    15 " si sebiji bisa masuk 150 db......
    BTW itu monoblok RFnya seri apaan??
    ya itu RockFord Fosgate 1800watt Monoblock Class D
    saya mo maen di 2 Ohm klo jadi :smt001
    sedangkan spec nya 2Ohm stable ..
    masi dalam proses barang2nya..
    3 Days 27 Mins 9 Secs
    gak bakal kenceng... loe maen 2 subwoofer di seri-paralel jadi 2 ohm, totalnya 1 sub cuma kebagian 900watt doank. itu pun kalo pas di maksimal peak powernya, tapi continuesnya gak bakalan sampe segitu. kalo loe cuma pake 1 sub, gimana caranya tuh dual voice coil 2 ohm dibikin jadi total 2 ohm? lu cuma mau pake 1 coil? gak bakal sampe 150db coy! kalo mau kenceng, powernya 4 biji, subwoofernya 2 biji....1 power gebuk 1 coil, nah kalo gitu 150db pasti tembus. saran gue gak usah pake power rockford...bukannya rockford jelek, tapi mahal coy. budget lu buat subwoofer aja udah gede, powernya pake monoblok AUDIOQUART 2500D aja, 4 biji cuma 17jutaan. kalo rockford 4 biji bisa sampe 30jt. buat bass aja abis 40jt sich over banget....
    FOCAL 3way Beryllium
    FOCAL 21WX
    FOCAL FPS2300RX (2)
    FOCAL FPS2160 (2)
    Pitch & Timbre
    12 Hrs 52 Mins 56 Secs
    kalo liat pic
    kayanya p6001bd
    rms 600w x 1 @ 2ohm
    jadi kurang tuw om..
    Quote Originally Posted by jengky_007
    @ TS : tuh kan gw bilang juga apah......
    itu power RF entry level....kayaknya kaga kuat tuh angkat RF 15 "....
    gmn bisa main di 2 ohm....wiringnya ga bisa ........bisanya pake 1 coil kalo 2 ohm...ga bakal kenceng.....
    @ jengky: 150 db mah gw yang ngomong boss...huahuahuahua...sebiji L7 15" pake box slot ported harusnya bisa tembus 150 db kog......asal powernya sakti....
    ]ya itu RockFord Fosgate 1800watt Monoblock Class D
    ati2 powernya yang jebol kalo mau di geber2....
    kirain pake RF seri BD.....
    enga 2 sub,gw pake 1 doang L7 15"-2
    RockFord yg di atas itu ada yg jual US $299 (masuk budget)
    budget gw cm 3jt ajah buat power
    hm...butuh masukan lagi neh hehe thankz..
    ato enga bisa gak subnya diangkat 2 power monoblock ??(contoh HDT 1200.1 2power)
    butuh masukan yg banyakk broo thankz skali lagii :smt002
    ID Ini Dicurigai Melakukan Penipuan.
    Indonesia, Chicago, Macau, Singapore
    2 Days 8 Hrs 33 Mins 28 Secs
    pake monoblock kicker dah hwahwahwha
    I will give an offer they can't refuse
GT Radial NGK Busi
  1. DiJual PWR ROCKFORD FOSGATE CLASS D 1000 WATT BD 1000.
    By awi hiki in forum Power Amplifier
    Last Post: 1st May 2012, 14:53
  2. SOLOBARIC L7 12"
    By ahja700126 in forum Speaker - SubWoofer
    Last Post: 27th April 2011, 23:41
  3. solobaric L7 12"
    By yudi setiwan in forum Diskusi Subwoofer
    Last Post: 19th August 2010, 23:08
  4. Solobaric L5 12"
    By pejaka tangguh in forum Diskusi Subwoofer
    Last Post: 3rd June 2008, 20:00
  5. Solobaric 12"
    By Cone in forum Diskusi Subwoofer
    Last Post: 12th July 2006, 13:13
