[CONNECTION] Planted // K20A Type R Honda Jazz
http://i763.photobucket.com/albums/x...psab0b3ca5.jpg
http://i763.photobucket.com/albums/x...ps56fc8990.jpg
http://i763.photobucket.com/albums/x...pse5fc936a.jpg
http://i763.photobucket.com/albums/x...ps1c86ace5.jpg
http://i763.photobucket.com/albums/x...psc2902c94.jpg
http://i763.photobucket.com/albums/x...ps4e93c4d7.jpg
http://i763.photobucket.com/albums/x...ps408374ef.jpg
http://i763.photobucket.com/albums/x...ps1cd70907.jpg
http://i763.photobucket.com/albums/x...ps56c8abb2.jpg
EXTERIOR
J’S RACING 3D CARBON REAR WING
SPOON CARBON REAR DIFFUSER
CHARGE SPEED ADD ON FRONT LIPS
OEM HONDA FIT JAPAN TAIL LIGHT
OEM HONDA REAR RED EMBLEM
J’S RACING FRONT TOW HOOK
J’S RACING REAR TOW HOOK
RAYBRIG RUNNING DAY LIGHT
CUSTOM CARBON HOOD
OEM HONDA FOG LIGHT PAINTED BLACK + CLEAR COAT
J’S RACING SHORT ANTENA
HDX HID BULB LAMPS
3M WINDOW FILM 80 BLACK TINT
FULL STICKER WRAP 3M WITH HONDA RACING STYLE BY LB STICKERS
WHEELS ETC
VOLK RAYS CE28 16×7 BRONZE et 42
TOYO R1R 205/50/16
TEIN SUPER FLEX DAMPER FULL ADJUSTABLE COILOVERS
CUSTOM END LINKS W/ REINFORCED CHASSIS
AP RACING PRO 5000+ 4POT WITH ROTOR 300mm
PROJECT U BRAKE LINES
PROJECT U REAR BRAKE PADS
MOTUL RBF 600 BRAKE FLUIDS
VOLK RAYS RACING LUG NUTS
ARP WHEEL BOLTS
CUSCO FRONT STRUT BAR
CUSCO REAR STRUT BAR
GREDDY FRONT UNDER BRACE BAR
ENGINE
1,998 cc K20A DC5 TYPE R JDM SPEC, FOUR-CYLINDER IN-LINE, NATURALLY ASPIRATED
DRAG CARTEL CAMSHAFTS 2.2 (13.5 lift Int./12.2 lift Exh. @50 deg. Cam angle duration)
SUPERTECH VALVE SPRINGS
SUPERTECH VALVE SPRINGS RETAINER
TODA FREE ADJUSTABLE CAM PULLEY
ARP REINFORCE HEAD BOLTS
ARP REINFORCE MAIN BOLTS
ARP FLYWHEEL BOLT
ACL MAIN & ROD RACE BEARINGS
PORTED & POLISHED HEAD W/PORT MATCHED INTAKE MANIFOLD
COSWORTH HIGH STOPPER METAL HEAD GASKET
TODA HIGH POWER TIMING CHAIN TENSIONER
NGK IRIDIUM SPARK PLUGS
CUSTOM ENGINE MOUNTS & TRANSMISSION BRACE
XS 3 INCH TITANIUM INTAKE PIPE + BOX
K&N OPEN AIR FILTERS
DC5 TYPE R INTAKE MANIFOLD PORT MATCHED
DC5 TYPE R THROTTLE BODY PORT MATCHED
DC SPORTS HEADERS 4-1 (Custom spec for GE8)
XS 2,5 INCH INCONEL CENTER PIPES
BURNS INCONEL RACING MUFFLER
KOYORAD FULL ALMUNIUM TRIPLE-FIN RADIATOR
J’s RACING LOW TEMP THERMOSTAT
J’s RACING LOW TEMP THERMO SWITCH
HYBRID RACING EXTRA FAN
INLINE HIGH CAPACITY FUEL FILTER
WALBRO 255L/H HIGH FLOW FUEL PUMP
SKUNK2 CARBON COMPOSITE BLACK FUEL RAIL W/ BUILT IN FUEL COOLING SYSTEM
HONDATA K-PRO ECU COMPUTER (Custom tuned 270BHP W/10.000RPM LIMITER)
AEM WIDEBAND BOSCH 02 A/F RATIO
HKS OBD LINK
HYBRID RACING STEEL BRAIDED CLUTCH LINE
DC5 TYPE R GEARBOX + CUSTOM XS SHORT SHIFTER
J’S RACING 1.5 WAY LIMITED SLIP DIFFERENTIAL
CUSTOM HARDENED STEEL XS AXLES
ATS HYPERSINGLE CLUTCH W/ CUSTOM SPEC THROW OUT BEARING
SPOON RADIATOR CAP
HYBRID RACING SLIM OIL CAP
J’S RACING MAGNETIC OIL DRAIN PLUG
HPI ENGINE DAMPER (CUSTOM SPEC FOR GE8)
TUCKED WIRES
TUCKED A/C
XRP RACE BRAIDED LINES
AEROQUIP HOSE END
AEROQUIP HEX FINISHER
REDLINE 5W40 ENGINE OIL
ROYAL PURPLE SYNCROMAX TRANSMISSION OIL
REDLINE POWER STEERING FLUIDS
REDLINE WATER WETTER
XS UNDER PANEL
INTERIOR
RECARO SR3 SEATS
M&M HONDA LOW SEATS RAIL
TAKATA 4 POINT SEATBELT HARNESS
MUGEN 360 STEERING WHEEL
HKB BOSSKIT
WORKS BELL TILT STEERING HUB
ARC TITANIUM SHIFT KNOB
AIM RACE DASH LOGGER STRADA MXL (INTEGRATED LINKED TO HONDATA & HKS OBD)
OEM DC5 PEDAL SET
CARBON PANEL INTERIOR
CLARION NX-702 DVD HEAD UNIT
CLARION HANDSFREE PHONE KIT
PIONEER COAXIAL REAR SPEAKER
HERTZ HX 250 D SUB WOOFER
POWER CRESCENDO SONATA 4
CAPBANK 1,3 F
